Auto lights again
Old May 21, 2016 | 03:08 PM
PDMiller's Avatar
Default Auto lights again
As part of an ongoing saga I've been trying to get the auto lights to work on my XK8 for as long as I've owned it. Other events of course take priority but every now and then I go back to it.. I've looked for broken wires and loose connectors wiggled light switch stalk etc but not a flicker.
Last week I jumped in the car late at night and set off on my journey home. After a while I thought "I didn't switch the lights on " but they were on! What an Idiot! I didn't realise the engine had to be running and assumed that they were the same as my X350 and worked with just the ignition switched on.
Next day I covered the sensor with some tape and drove around as normal. It seems that the auto lights come on sometimes when the sensor is covered but always go off when the tape is removed.
Anyone think it's a faulty sensor? If so I'll continue to switch off and on manually.
Old May 21, 2016 | 08:54 PM
scardini1's Avatar
Might be a faulty sensor connection too. Pull the speaker out from your dash - the connector can accessed from there.
Old May 22, 2016 | 09:53 AM
PDMiller's Avatar
Thanks Jim.
Are you referring to the speaker in the overhead console, the one with the interior lights? I'm not sure how to get that console off without breaking something, it seems to be well secured. You could be in the right area because today with the sensor covered the lights didn't come on, I touched the mirror and on they came.
Pete
Old May 22, 2016 | 11:57 AM
scardini1's Avatar
Originally Posted by PDMiller
Thanks Jim.
Pete
No,no. That's Not a speaker in the overhead. It's a position sensor for the pax seat air bag. I'm talking about the speaker grill on top of the dashboard outside of the sun light sensor . It just pries out easily. The sun sensor connector
Is beneath.
Old May 22, 2016 | 02:07 PM
PDMiller's Avatar
The sensor that I have taped over is on the back of the mirror and it seems to be sort of controlling the lights when it feels like it. I thought the one on the dashboard was for the heating system. These cars are full of surprises. More investigation required.
Thanks for the input
Old May 22, 2016 | 02:56 PM
scardini1's Avatar
OK. This Is good. You're on the right track now . That little black dome on the dash is your sunlight sensor. The HVAC sensor is behind the little grill in front of your right knee.
buttpt
Mar 31, 2016 04:48 PM
Dean Kitching
Mar 30, 2016 02:53 PM
dsnyder586
Mar 30, 2016 09:47 AM
alecescolme
Mar 29, 2016 03:27 PM
Chrishughes
Mar 29, 2016 08:48 AM
