Bang then no drive
Old Apr 30, 2011 | 12:10 PM
mrdobsie's Avatar
Default Bang then no drive
driving along normal road with mini roundabout... drove/rode this mini roundabout then a slight clunk on rear side (driver's side) no other mechanical sounds then total loss of drive ... gear box did not show any faults/ warning lights. No drive warning lights etc.. but just total loss of drive. Any ideas... Diff problem?? Torque converter??? Thanks in advance. Martin
Old Apr 30, 2011 | 12:58 PM
mrdobsie's Avatar
Had a look a the drive shaft doughnut...Rubber connection to the auto box..all is fine..I guess this may be the final drive in the gearbox that has let go??
Is this a difficult part to replace as i have my last broken gearbox here at my place and could do without the expense of another recon
Thanks in advance
Martin
Old Apr 30, 2011 | 07:01 PM
test point's Avatar
I am certainly not a transmission expert but the failure of the A/B (1/2) drum is a well known problem. That is a only a guess but probably not far off. Can be replaced without a complete transmission rebuild but once it is out labor becomes the issue.
Old May 1, 2011 | 04:57 AM
mrdobsie's Avatar
Thanks..Would the AB 1/2 drum failure not give a gearbox fault light on the dashboard?
No Lights and no drive..The engine changes note when you put into drive or reverse..So the torque converter is working i guess..Is this not a final drive fault?
Old May 2, 2011 | 01:37 PM
H20boy's Avatar
are your j-gate selection indicators blinking or displaying what gear it is in?
Old May 2, 2011 | 09:11 PM
mrdobsie's Avatar
Everyting as normal even in J gate?
Whaddya thinkin?
Old May 2, 2011 | 10:04 PM
Gus's Avatar
Gus
You should get a reading of your OBD II codes and see what it gives you. Post your codes and we can help.
Old May 3, 2011 | 09:14 AM
oldmots's Avatar
It's obvious that you need to get it to a shop. They will look at the components to be sure it's not something like a broken u-joint or CV joint in the rear, then check fluid level. Check codes to see if there is anything there and go from there.
Old May 8, 2011 | 01:44 PM
EZDriver's Avatar
Please keep us informed as to what is found.
EZDriver 2000 XK8
99xk8guy
May 28, 2024 09:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
JimMLiny
Sep 9, 2015 08:13 PM
skadmiri1
Sep 9, 2015 11:27 AM
handcuffsready
Sep 7, 2015 03:16 AM
