Battery care
Hi all,
as cold weather came to Poland, my XK8 convertible is going for a 5 months sleep. What would you recommend - should I take the battery out, or leave it in the trunk and just charge every 2-3 weeks?
Thank you 😉
Thank you 😉
I keep mine in the boot of my 1999 XK8 coupe and have it on a C-Tek battery maintainer ( https://smartercharger.com/ ) throughout the winter months. I found out about the C-Tek on this forum after several other battery chargers failed. So far I am happy with the C-Tek and also got a second one for my 1989 Honda NightHawk 450 motorcycle. Both vehicles have AGM batteries.
I'm not sure C-Tek maintainer are available in Poland.
+1
Fortunately, I do not have to store my car for the winter. However, my wife and I do travel quite a bit, so I use a CTEK when away for a few weeks at a time.
Stu
Stu
Grab a ProMariner charger. Made for boats, but I've used them for semi trucks and cars too. Excellent quality. And the circuitry and computer in them checks your battery out. Decides whether it needs a full charge, a maintaining trickle, or even a full maintenance routine which will make your battery brand new again. I highly recommend them.
CTEK's are available for the European household voltage, so you can always mail order one to Poland. Check to be sure that the one you order conditions the battery. These are great units.
the Ctek lead easily extends through the boot lid gasket and they make connectors that you can permanently attach to the battery and extend into the boot for ease of attachment.
Sorry it took a while for my reply.
Your describtion just indicates the good condition of your battery.
Whenever I wait 3 weeks or so to put on the charger after I put the car away, it will take more time to cycle, but when I put it on immediatly after use than I see it jump immediatly to trickle charge.
If you use the leads under the motor compartment, there is a fuse that offers some protection.
