Battery charge readings
Old Feb 2, 2013 | 06:20 PM
artstar's Avatar
Default Battery charge readings
Just out of curiosity what are "good" battery voltage readings across the posts? I used a digital MM and the charge on a 24-36 hour not driven car was 12.25V, 12.45-12.46 right after driving it and 14.03V while running.
Old Feb 2, 2013 | 06:29 PM
test point's Avatar
Technically, the fully charges rest voltage should be 12.6v fully charged. The car's charging system is designed for 14.5v plus or minus a couple tenths while running. After burning off the surface charge by turning the lights on or cranking it a few revolutions without starting the voltage should still be above 12.0v. Anything less indicates a failing battery.
Both your running and rest voltage seems low. Most auto parts stores will do a free battery/charging system check.
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
jaguarbill
Sep 5, 2015 11:43 AM
