Best place to get suspension bushings?
Old Jul 22, 2010 | 07:18 AM
hm1's Avatar
hm1
Default Best place to get suspension bushings?
Where to order or drive to get in Miami? I need the upper shock mounts, and I might as well do the sway bars. How much would I expect to spend on parts?
Old Jul 22, 2010 | 07:30 AM
Reverend Sam's Avatar
I'd like to know, too. A while back h20boy posted a link for some urethane bushings but I can't find the link anymore.
Old Jul 22, 2010 | 07:50 AM
MarcB's Avatar
I'm not sure about the best place, but I have Powerflex bushings in my XKR. I purchased them 2 years ago from the U.K. because I couldn't find them in the U.S. I have provided the web link for the (new to me) U.S. site.
http://store.powerflexusa.com/jaguar-xk8-p1182.aspx
Old Jul 22, 2010 | 07:59 AM
hm1's Avatar
hm1
Wow, fast replies. I'm looking for factory rubber, not sure about putting urethane's on my xk.
Old Jul 22, 2010 | 08:14 AM
MarcB's Avatar
I would not discount the poly, the ride changes very little and they will las a lot longer meaning your alignment will stay true longer as well.
As far as OEM type (you definitely need the OEM type with the sleeves where they are applicable) I would try the usual suspects:
  • jagbits.com
  • welshent.com (they are not listing bushings ob there site but I'd call them).
Old Jul 22, 2010 | 08:18 AM
hm1's Avatar
hm1
Thanks!
Old Jul 22, 2010 | 09:51 AM
H20boy's Avatar
Jaguar OEM sway bar bushings are about $13 each. Upper mounts, sorry don't know. If I were to do it again, I'd get the poly for the sway bar, and even the control arms too. The OEM rubber doesn't last as long.
I measured my XK8 sway bar and was going to try the red poly bushings, though not 'custom' like polyflexusa's, but only 1.5mm smaller than the bar IIRC. I do have a link somewhere and the information about the sway bar diameter in one of my many threads.
Old Jul 22, 2010 | 05:54 PM
MrTexasDan's Avatar
Here's a repeat from another thread ... (note: this is for OEM type rubber, not that fancy space-age stuff you kids like so much).
Do you have access to a hydraulic press?
If you're going to tear apart your front end, you could replace the items that chronically wear out:
Upper shock mounts
Lower shock bushings
Upper and Lower ball joints
Upper and Lower Suspension arm bushings
... and while you're in there:
stabilizer arm links
stabilizer arm bushings
steering rack bushings
steering tie rod ends
This basically gets you a new front suspension.
Total parts cost ~ $520 from
http://www.britishparts.co.uk/.sc/ms...ing-Suspension
scooternva
29
Mar 25, 2025 12:45 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
