Best replacement shocks with lower bushings?
Old Oct 8, 2013 | 08:42 AM
philhef's Avatar
Default Best replacement shocks with lower bushings?
I'm in the process of gathering everything I need to restore the front of my car to the factory height. I saw a thread several weeks ago and someone had replaced bushings, everything actually and had mentiond an aftermarket shock that came with the lower bushing.
I've ordered the top mounts, debating the springs tho due to costs. But if that's what I need, I'll get them. My front is about 1 1/2" too low.
Any shopping list of parts would be helpful!
Old Oct 8, 2013 | 09:20 AM
Jag#4's Avatar
If I remember from your posts, this is not needed as a daily driver. So I would get it up in the air with wheels off and take a look. With 1 1/2" drop I'm thinking you need upper shock mounts and coil springs. You are only going to gain ~1/2" with top shock mounts. Shocks are a factor, but springs have more to do with ride height.
However, while you have it up (jack stands or lift) take a look at all the bushings. Rubber wears out and deteriorates in all cars. And you're already there, so...
Old Oct 8, 2013 | 10:19 AM
The Coupe's Avatar
Phil, here's my recent project with shocks, mounts, springs, etc...complete with part numbers, costs, etc.
New front springs, shocks, mounts, the works...LOTS OF PHOTOS
JarodL
Mar 7, 2024 01:39 AM
bdboyle
Sep 4, 2015 06:16 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
