blower issue
Old Aug 23, 2016 | 11:40 AM
double d's Avatar
Default blower issue
Wondering if there a code I should be looking for in trying to figure out why my blower blows fine at idle then stops on acceleration.
wondering if a actulator isn't working right and if there was a code I would know which one ???
Old Aug 23, 2016 | 11:43 AM
jimbov8's Avatar
If you are referring to the blower inside the cabin, if you have the a/c on auto then as you speed up the blower will reduce in speed. This quite normal.
Switch to manual mode and see if it still slows down.
Old Aug 23, 2016 | 12:52 PM
fmertz's Avatar
This document has been provided before (not mine). It lists a complete diagnostics procedure, including a display of codes.
I would also check the ambient temperature sensor (ext. temperature on the display)...
Old Aug 23, 2016 | 05:51 PM
double d's Avatar
Default still checking
Well has been busy day ,checked ambient sensor all good ,checked no codes
I have auto and air off ,
noticed when turn ignition on blower great ,start car slows down ,rev car stops .
also noticed at idle and if I turn headlights on ,then to high it speeds up blower motor ,but still stops when I rev up motor ,still on the hunt ,any ideas ???
I realize this car is all new to me but I should be able to figure this out as on my other cars I can fix myself but maybe not this one ?????
curtizb
May 24, 2016 03:28 PM
juha_teuvonnen
May 12, 2016 09:07 AM
Johnnyxk120
Apr 27, 2016 04:10 PM
Alex8027
Sep 14, 2007 03:08 PM
