Bluetooth connectivity
Old Dec 25, 2016 | 10:01 AM
Saajan_B's Avatar
Default Bluetooth connectivity
Hi again, I hope everyone is having a good Christmas.
In my X100 2005 4.2 S it says it has Bluetooth capability on the specification sheet. When I try to pair the phone the radio says "no phone". I've tried the clear button trick and all the pairing codes to no avail.
It is a premium alpine system with CD changer and navigation system. I've taken out the centre console and found a Bluetooth module model no. 3w83-14b409-aa. The yellow connector is connected to a loom but I can't seem to locate the pse module. I've looked by the amp CD changer stack in the boot.
Does anyone know where the pse module is and how to get it to communicate witj the radio again?
Thank you
Old Dec 25, 2016 | 01:29 PM
On the bulkhead behind the rear seat back.
I'd suspect a problem with the pairing procedure rather than the hardware unless a PO has modified it.
Old Dec 26, 2016 | 07:45 AM
Saajan_B's Avatar
What I can see behind the trim in the boot
Yellow connector, could this be for the pse module?
I still cannot locate the pse module, is it behind the fuel tank?
Old Dec 26, 2016 | 08:50 AM
dibbit's Avatar
You are looking on the wrong side of the bulkhead - it is inside the passenger compartment, behind the seat back - you have to take the seat back off to find it.
