Body Control Module - How to access?
Old Aug 7, 2014 | 01:19 PM
Johnken's Avatar
Default Body Control Module - How to access?
Friends, I am tired of fighting with my steering wheel's tilt/extend mechanism. It seems logical to me that if the memory and Auto function work the tilt/extend 100% of the time then the problem has to be in the circuit between the switch (which test OK) and the body control module [BCM] (wire diagrams show a direct connection from the switch to the BCM).
I looked, but there is little space for access and I can't see anything. Someone once said it is a blue box. I thought you may have more specific instructions so I wanted to ask - how does one get to the BCM on a 1998 xk8 converible? Any assistance would be greatly apprecaited.
Yes, I'll admit it - I am hoping it is a corroded connection between the wire and the BCM, but I know the odds of that are pretty slim. Seems like a good place to start, I'll let you know what I find.
Thanks - John
Old Aug 7, 2014 | 09:37 PM
Jag#4's Avatar
Not sure the BCM would be part of your problem. If it is the tilt and extend feature of the steering wheel, then this is a common issue with the reach motor.
The DIY section in the main page stickies is a good start for the cure. Here's some links found there.
http://www.jaguarforums.com/forum/xk...-w-sound-4816/
http://www.jaguarforums.com/forum/xj...-1998-a-17191/
Old Aug 9, 2014 | 12:58 PM
Johnken's Avatar
Thanks Mike, but how can it work perfectly with auto extend and with Memory, but not the switch if it is the motor? John
H20boy
Dec 24, 2024 03:23 PM
Steviedee1st
Nov 28, 2023 06:32 PM
XJsc-guy
Sep 25, 2015 11:09 AM
abonano
25
Sep 25, 2015 10:43 AM
jaguarbill
Sep 5, 2015 11:43 AM
