Boston Acquistics
is anyone familiar with the wiring of these systems?
Is there a reading i should check to make sure my amp is functioning? I have an 2006 XKR Victory Edition and the Alpine Sound system. Were the Boston Crossovers in the door standard??
As far as I know the whole system as it left the factory was Alpine. Maybe if you describe what problem you are having people can give you some ideas, but I would start by making sure all the fuses for the audio system are intact.
Well i took the door apart because some of the clips were busted. Inside the door was a TweeterWoofer Crossover (PRO60SE) manufacturted by Boston Acquistics. It was doubled taped to the door. Anyways i picked it up and it was like spagetti, sounded like rice. I'm sure the thing is NOT working. So now I purchased duplicate Cross Overs that I found on Ebay. I'm wondering how I can check to make sure that these will make a difference in the sound? Will I be able to hear the radio with the top down going 70mph?
Anyway, a previous owner added those crossovers. The stock system sends mid-range and high-range freqs to the doors, the tweeter is wired in parallel with the mid, and the tweeter has a capacitor soldered to it, presumably as a filter. The doors have no separate crossovers.
In that case, the PO replaced the stock ones. The stock ones are Jaguar branded and are cheap paper cones. I have no idea how, but my car's PO fried ALL the door speakers, woofers and tweeters.
I upgraded mine to some 2-way Infiniti Kappas, but it was a waste. None of the high freq signal gets to the door mount speakers. Frankly, little midrange gets there either. They're almost like mini-subwoofers, for lack of a better term. Just about all of the mid-range stuff, by design, goes through the dash mounted speakers.
So, if you're keeping it stock, any decent 6.5 inch speaker will do.
jagxkrtoofast
Aug 24, 2018 09:41 AM
