Brake Hose Size
Old Nov 21, 2014 | 12:04 PM
DevonDavid's Avatar
Default Brake Hose Size
Just thinking ahead ............ one of my winter jobs will be to remove all four brake calipers for a clean / paint etc, plus renewing seals etc.
As they will be off for some time, I intend to buy some plastic caps & plugs (female for the end of the flexible pipe and male for the hole in the calipers) and just wondered if anyone knew what size to get (and are front and rear the same size ?)
Not Brembo - just the "standard" XK8 - 1997 - brakes.
Thanks in advance.
Cheers,
David.
Old Nov 21, 2014 | 02:59 PM
sheddist's Avatar
Brake pipe hose is M10 X 1 and for the rear it is a banjo bolt, again M10 X1
When you refit the rear, new copper washers should be fitted.
Forcedair1
Sep 8, 2025 01:57 PM
clubairth1
30
Sep 3, 2025 04:38 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
KarimPA
Sep 12, 2015 08:15 AM
d a
Sep 3, 2015 02:34 AM
