brakes
Old May 14, 2013 | 03:33 AM
dodgerjames's Avatar
Default brakes
just came back from shops and a noise from the brakes started (grinding)looked at dash and the engine light was on, with dsc warning,info please and is it safe to drive.......thankyou (urgent)
Old May 14, 2013 | 03:51 AM
Grinding brakes could be as simple as gravel trapped between the disc and the back plate but is more likely to be a pad down to the metal.
Check the pads and calipers a.s.a.p. Apart from the risk of uneven or lost brakes, if a pad is right down, you'll destroy the disc in no time.
Old May 14, 2013 | 04:15 AM
what does dsc or dcs stand for please?
Old May 14, 2013 | 04:33 AM
DSC = Dynamic Stability Control
This controls the Anti-Lock Braking system (ABS), Traction Control (TRAC) and Yaw Control of the vehicle.
There are three associated messages can be displayed in the Message Centre:
1. DSC SYSTEM FAULT
An amber warning message indicating a fault. It is safe to drive the vehicle but DSC may not activate under wheelspin or slide conditions.
2. DSC
An amber warning indicating DSC is operating (this is normal)
3. DSC SYSTEM ON (or OFF)
Indicates DSC has been turned On (or Off) using the dashboard switch. Displays for a maximum of four seconds
Old May 14, 2013 | 08:17 AM
oldmots's Avatar
You have a bad brake job. I would get right back there and get it sorted. The chances are good that the link lead for the ABS has been damaged or disconnected as well as the wrong disk pads put back.
Old May 14, 2013 | 08:45 AM
went back out and the light was gone,no noise and seems all good so hoping just a bit of grit or stone which is now gone so hopefully resolved
PMKimpton
Aug 3, 2019 08:22 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
