Breather hoses
Old Nov 6, 2014 | 02:14 AM
oyster's Avatar
Default Breather hoses
Hi all.
Had the infamous codes P0171 and P0174. Also occasionally reduced performance message. Fuel trims hovering around 15% on the rich side. Revving to 2500 rpm returned trims to around zero. Suspected air leak.
Spraying with carb cleaner while monitoring fuel trims indicated leak at lower left side of throttle body. Suspected part load breather tube connection to TB.
To get at it you have to remove TB or coolant tank.
Removed TB, hardest part getting the coolant lines off. Almost no coolant spilled out.
Part load breather hose very brittle and totally crushed around T-piece connector to throttle body elbow lower left side.
Replaced hose. No problem routing it through intake manifold, Pulled the new one with the old one.
Also replaced full load breather hose. Looked good, but the small rubber gaskets were old. Both hoses fairly cheap.
Problem fixed. No more warnings or codes, and fuel trims hovering around zero.
Old Nov 6, 2014 | 08:32 AM
brgjag's Avatar
I keep seeing folks talking about "Part load breather hose very brittle" What is this hose????? Where is it?
Old Nov 6, 2014 | 08:41 AM
RJ237's Avatar
On top of the left valve cover near the front.
Old Nov 6, 2014 | 12:28 PM
brgjag's Avatar
just that one hose others like it?
Old Nov 6, 2014 | 12:53 PM
RJ237's Avatar
I do not understand your question.
Old Nov 6, 2014 | 01:37 PM
randyb's Avatar
Yes, there are several other hoses using this design.
Old Nov 6, 2014 | 01:57 PM
brgjag's Avatar
how many breather hoses on a 03 Xk8?
Old Nov 6, 2014 | 03:49 PM
oyster's Avatar
Here you go:
Attached Thumbnails Breather hoses-breather-hoses-i.png   Breather hoses-breather-hoses-ii.png
mikiep
Dec 20, 2019 07:37 PM
NathanDD6
Oct 6, 2015 11:20 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
