Brembo capliers part number
Old Apr 30, 2011 | 07:44 AM
DISCOSTU29's Avatar
Default Brembo capliers part number
Does anyone know the part number used for front or rear brembo calipers?
Stamped on the back of the Brembo calipers. I bought a set rear calipers from ebay but I think they are fronts, havent managed to get the old standard calipers of yet to see which I have recevied.
Old Apr 30, 2011 | 08:30 AM
macbut999's Avatar
Welcome to the forum Stu,congrats on getting some Brembos on the cheap.I will take a look at my calipers and see what i can discover for you.I have measured the size of the calipers very approximately as i still had wheels on.
Fronts are 255mm approx Back are 215mm approx
BTW you need 20" rims to fit Brembos,just on the off chance you have standard size rims,the flexible brake pipes are different from standard calipers too depending upon VIN.
Old Apr 30, 2011 | 08:51 AM
Reverend Sam's Avatar
The fronts are HUGE and the rear calipers are about the size of the standard front calipers.
Old Apr 30, 2011 | 09:21 AM
Goldlion's Avatar
Well, just thought I would clear up the use of Brembos and wheel size. I have the factory Brembos front and rear and I also have the 18'' Jaguar Hydra Wheels. The Brembos were available as an option on a couple of the Jaguar 18" wheels, the Hydra design being one. The fit/clearance, however, is tight. And, the flexible brake pipes/lines are indeed different. The Brembos do an excellent job of stopping and are rather resistant to performance fade when driven hard.
Hope this will be helpful.
Old Apr 30, 2011 | 01:07 PM
DISCOSTU29's Avatar
The calipers measure 270mm in lenght thats not including the brake pipe that links both sides. They were advertised as off a 4.2 S-Type or XJR rear. They were only £100 buy it now ebay, thought I would take a chance.
I painted them first. Maybe should have tried to see if they fit.
Not sure what size of discs i need.
Old May 2, 2011 | 04:51 PM
govatos's Avatar
I believe the front rotors are 355mm and the rear 325. That looks to me like a front caliper in your photo.
Old May 2, 2011 | 06:18 PM
I thought disc size didn't matter.
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
Doug
Feb 27, 2019 01:31 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
