Broken headlight body tabs
Old Jun 20, 2009 | 03:54 PM
jgivoo's Avatar
Default Broken headlight body tabs
Have a 2007 xk8. Right side headlight has broken mounting tab. I have a spare right side headlight with perfect body but cracked lens. Is there a procedure or instructions to separate the lens from the body so I can make one good headlight out of two??
Old Jun 20, 2009 | 08:03 PM
test point's Avatar
The lens is just glued in place with a silicone adhesive. Use an utility knife to separate. Do not . . . repeat . . . . do not . . . attempt to clean the silvered interior of the body. Mine just wiped off.
Old Jun 22, 2009 | 10:31 AM
jgivoo's Avatar
Looks like I will try and repair the tab. After input from this website, getting the lens off and putting back on with a water tight may be a bit too challenging.
Thanks again
Joel
trosty
26
Dec 18, 2022 06:40 PM
afterburner1
Dec 16, 2015 12:12 AM
mikimogo
Sep 14, 2015 08:34 PM
avern1
Sep 8, 2015 06:25 PM
tberg
Sep 7, 2015 07:32 AM
