Build Thread: XK8 Convert EV
Old Jul 15, 2016 | 04:23 PM
  #101
K.Westra's Avatar
Wow...that's a lot of batteries. Any ideas on a before/after weight comparison and weight bias?
Old Jul 16, 2016 | 01:19 AM
  #102
jaggedy's Avatar
Wow! Moving right along!!!
I can't wait to see a video of you pulling out of your garage and driving around town!
Old Sep 27, 2016 | 10:36 PM
  #103
rui's Avatar
rui
Has it seriously been 2 months and I have nothing to show for it?!
well, Here are quick update:
・so, removed the rear seat for sell and I've noticed that on the back of it, it say 883 WB....now, does that mean 883rd xk8 coupe made?
・managed to cut out the rear seat firewall (harder than I thought)
Next up is to make the rear battery boxes with automotive slide rail!
(hopefully I can get it done by the end of next month!)
Old Sep 28, 2016 | 12:13 AM
  #104
Jandreu's Avatar
Thanks for the update, just keep moving forward none of us want to see you give up. This is one hell of a build!
Old May 5, 2017 | 03:27 AM
  #105
jaggedy's Avatar
Hi Rui!
I hope all is well!
Old May 7, 2017 | 07:15 PM
  #106
rui's Avatar
rui
Originally Posted by jaggedy
Hi Rui!
I hope all is well!
Thanks for the heads up!
I am still alive and well, The project is still going but due to my work load, it's going at snails pace...
I'll upload some photos later on but the rear end battery box has been completed. I am now working on Slide rail mechanism.
(waiting on custom parts to arrive as well)
My new goal is have it running by the end of this year!
Old May 7, 2017 | 10:14 PM
  #107
Jandreu's Avatar
Keep at it buddy, you have our attention and admiration for doing this project!
Old May 7, 2017 | 11:06 PM
  #108
Burnham's Avatar
Indeed!
Looking forward to the next installment of the story.
Old May 12, 2017 | 10:29 AM
  #109
cdre's Avatar
Very cool. Looking forward to any updates.
Old Jun 13, 2017 | 10:41 PM
  #110
rui's Avatar
rui
Super long over due update!
I've been working on rear battery box for decade now....lol
I don't know where the time went but here are some updates.
So far, I've worked out the Sliderail mechanism and started fabricating the boxs(2). Two of these boxes will store 24x2 batteries.
First picture is where I had to make the hole for the battery compartment little higher and attached rubber protection around it.
I've found some cool parts while making it;
Do you guys know what U-nut is? (video of it in Japanese)
It's a type of a lock-Nut that's simple and reusable. So, I've decided to use these for the rail fixture.
Battery compartment increased in hight
Taper M5 12mm bolt + U-nut
Battery box complete (need to paint it)
Slide rail ready to install!
Next up:
- Needs to paint the box and start making the car side of the rail fixture.
- rear passenger battery box to be made
- Front ICE(motor) compartment area design
Old Jun 13, 2017 | 11:01 PM
  #111
jaggedy's Avatar
Looking good!
I am not clear about the sliding mechanism.
For easier access, the batteries will slide from the gas tank area into the cabin?
Old Jun 13, 2017 | 11:05 PM
  #112
rui's Avatar
rui
Looking good!
you are correct! Batteries will need to be monitored every now and then, so to make my life easy and to make it good to display, I've added the sliderail.
Old Jun 13, 2017 | 11:20 PM
  #113
chillyphilly's Avatar
Nice! I am very intrigued with your project. What is your projected parts cost for the build?
Old Jun 13, 2017 | 11:34 PM
  #114
rui's Avatar
rui
Oh God...don't mention it...but here is an excel sheet i've made for the project.
EV Budget.xls
But, the long story short, I've spent roughly ‎£35k !
・most expensive being the battery at a cost of £10K
・initial car was about £5k
・Motor, controller, charger are £3k, £2.5K and £2.8k
・rest are electronic components, few car upgrade parts and tools
Old Jun 14, 2017 | 05:43 AM
  #115
laguillotine's Avatar
Just found this thread and its equally beautiful and crazy; chapeau sir!
Old Jun 14, 2017 | 12:10 PM
  #116
jaggedy's Avatar
I am sure that you will engineer a very solid locking mechanism for the box and barrier door for the compartment.
It wouldn't be any fun to slam on the brakes and then be hit in the back of the head with a hundred kilos or so of batteries...
Old Jun 14, 2017 | 02:55 PM
  #117
Jandreu's Avatar
Rui, very nice, must be a labor of love!
Old Jun 15, 2017 | 12:33 PM
  #118
Pristine97XK8Convertible's Avatar
Rui,
Keep going and let us know your progress. We're behind you all the way!
Old Jun 21, 2017 | 11:04 PM
  #119
Burnham's Avatar
Always enjoy reading your latest update. Thanks!
Old Jun 22, 2017 | 01:38 AM
  #120
rui's Avatar
rui
I don't have much of an update but here are the latest.
I've finished making the rear battery box and did the test fitting...
well, the height is perfect but the width is not
Due to the slight curve on the bottom sides, I must have miscalculated the length...Needs to make the hole bigger...again...
perfectly alined rails!
Not so perfectly fitting box...
Since i've updated my tool wall recently, I thought i'll share it with you guys!
My garage/Work tools!
Next up:
- Cut out more rear end firewall (might as well clean the area)
- making the car side of the rail fixture.(got an idea for it)
