A/C Compressor Engagement Failure Troubleshooting
Old Jun 19, 2023 | 02:05 PM
reedhatkoff's Avatar
Default A/C Compressor Engagement Failure Troubleshooting
RE: 2000 XKR
My A/C compressor is not engaging with car running when the A/C switch is pressed.
Checked the 10A fuses- O.K. Did NOT check the A/C Compressor Clutch relay... how does one check a relay?
Would a low refrigerant (pressure) be indicated in preventing the compressor activation?
What would the simplistic troubleshooting hierarchy of steps be?
  • IF fuse(s) OK ->
  • Check relay?
Thanks for the advice...
__________________
2009 XKR Convertible
Old Jun 19, 2023 | 02:55 PM
RJ237's Avatar
To me he simplest test would be to measure the pressure in the A/C system with the engine running and A/C set to cold and fan on high. Several auto parts stores will loan the test gauges, which come with instructions. Odds are pretty good the system pressure is too low and the clutch will not engage.
trumpet
Jun 27, 2022 03:43 PM
bullittandy
Jun 19, 2022 05:00 PM
pixiesjag
XJ40 ( XJ81 )
Jun 2, 2019 05:43 PM
supra-raleigh
XJ40 ( XJ81 )
Oct 15, 2014 09:32 PM
prrthdtx
Nov 24, 2010 08:01 AM
