A/C failed
Old Apr 13, 2014 | 07:50 AM
RJ237's Avatar
Default A/C failed
The cold air became warm yesterday. Codes 11, 14, 24 are displayed, but after checking JTIS I am still confused. The 14 and 24 actions are to refer to PDU. What is that?
Old Apr 13, 2014 | 09:19 AM
It's a Portable Diagnostic Unit.
All the faults indicate sensor/signal failures so maybe a fuse or a wiring fault?
Old Apr 13, 2014 | 09:33 AM
jimbov8's Avatar
https://www.jaguarforums.com/forum/a...rror-codes-pdf
Try looking through these, it may help.
Old Apr 13, 2014 | 10:09 AM
RJ237's Avatar
Thanks guys. I've already been through the code explanations and agree it might be a circuit problem. But "refer to PDU" means nothing to me.
I reset the codes and will take it out this afternoon to see if they repeat. It may be time to break out the wiring diagrams again.
Old Apr 13, 2014 | 11:16 AM
RJ237's Avatar
After reset the problem went away, blowing cold again. I hope it stays that way.
For todays' trivial fact: the motorized aspirator samples cabin air to control temp. and is behind the little grill next to the valet button on US cars. I undoubtedly disconnected it when installing the Realgauge over a year ago and the code has probably been stored since then.
Old Apr 13, 2014 | 11:23 AM
JTIS was intended for use by Jag technicians, so when the saw that they would just hook up the PDU, unfortunately you can't.
aode06
Jul 28, 2023 02:26 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
