a/c out for 2 years now on 99 xk8
Old Jul 20, 2009 | 12:55 PM
rld14's Avatar
Get in touch with Bill Suter at All Jaguar in Longwood, just north of Orlando. WELL worth the trip.
Tell them Bill Junior sent you.
Old Jul 22, 2009 | 09:44 AM
rld14's Avatar
If I trust anyone in the southeast to fix a Jag, it's Bill Suter.
Quick question, did you replace the receiver/drier? Whenever the system is opened that ought to be changed.
Old Jul 22, 2009 | 10:31 PM
poboyblues's Avatar
You may have a condensor leak, as well. These leaks usually occur at the bottom of the condensor. Also your system may have a blockage. Most blockages are in the dryer, which you had replaced, or the expansion valve. Have your ac tech hook up gauges and see what she's doing. Should be easy to figure out if the tech is savvy. One other leak you may have, which I've personally have never encountered on any XK, is the evaporator. These leaks are very hard to find, unless you have a high quality sniffer that can alarm the tech if there is a leak.
99xk8guy
Sep 29, 2025 10:51 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Dicque
Sep 19, 2015 12:53 PM
jehart49
Sep 12, 2015 05:36 PM
David Thompson
Sep 3, 2015 07:48 PM
