C1175 code stored
Old Oct 21, 2010 | 10:44 AM
XKR Brian's Avatar
Default C1175 code stored
Has anyone has experience with this. It translates to left rear wheel sensor if I am not mistaken. It only happens when cold and wet. I am thinking a poor connector connection on the sensor harness connector, but searched it and no one else has reported this concern. Oh the abs, traction and check engine lights come on witht this as well.
Old Oct 21, 2010 | 12:12 PM
H20boy's Avatar
haven't, but hopefully its minor, as you said, wiring or connector. Worse case you can swap sensors to other side can't you to see if the code jumps...then its the sensor.
Old Oct 21, 2010 | 01:02 PM
XKR Brian's Avatar
yea just havent had anytime to put it in the air as of yet.
Old Oct 22, 2010 | 09:31 AM
H20boy's Avatar
should be a nice weekend for that very job let us know
Old Oct 29, 2010 | 06:45 PM
XKR Brian's Avatar
ok so I finally got a chance to get it up in the air and found the left rear abs harness stretched due to the way it was routed. I changed the direction so it goes over the brake line and cleaned the connector and sensor pins. While I was at it I took a look at the cogs on the axle and found them to be almost completly filled with dirt. I cleaned them off on both axles. The end result? I have no more lights on. car excellerates harder around right turns without setting the light off as well. (This part must be the tension that was on the harness) Hopefully I wont be haveing to replace the harness any time soon, as it does not look as if it is a simple subharness like the front ones.
Old Oct 29, 2010 | 10:38 PM
H20boy's Avatar
A happy ending! (and no oriental massage required either)
Old Oct 30, 2010 | 10:42 AM
XKR Brian's Avatar
yeah, I just left that part out
Jpav27
Jul 31, 2022 06:43 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
chatmanx
Sep 11, 2015 07:17 PM
tonyforman
Sep 10, 2015 07:23 PM
1964Daimler
Sep 9, 2015 11:20 AM
