C1288 Fault code
Old Mar 9, 2016 | 01:32 PM
hub61's Avatar
Thumbs down C1288 Fault code
Hi, '03 XK8 4.2 has "DSC system fault" Amber warning which turned up C1288 "Pressure transducer input circuit failure".
This leads me to suspect part no.XR828106 needs replaced, anybody done this for this fault code? and, Was it successful?
Lots of previous posts have mentioned cleaning ABS wheel sensors and/or re-soldering ABS module so not needing further info on this job.
Thank you.
Old Mar 11, 2016 | 09:41 AM
Welcome to the forum hub61,
270 Views but no Replies - extraordinary!
JTIS (Jaguar Technical Information System) gives this for C1288 (see Possible Causes in the right hand column:
Could be either a harness or a sensor fault.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Mar 12, 2016 | 10:58 AM
hub61's Avatar
Cheers, hopefully be helpful
klfong
Mar 6, 2016 12:08 AM
Bill D
Mar 4, 2016 10:22 PM
KayScotts
Mar 4, 2016 05:51 PM
andyzeg
Mar 4, 2016 12:01 PM
Frankie
Mar 3, 2016 08:33 AM
