Can the alternator be turned off temporarily?
Subscribe
Dec 10, 2024 | 09:31 PM
I am hunting a ground loop issue with my audio system and i want to find out if the alternator is the culprit. Is it possible to take the alternator out of the electrical loop for a short time for me to do a test. I don't see a relay or anything i can just pull to test this out.
Reply 0
Dec 11, 2024 | 01:50 AM
No relay you need to pull the three pin plug on the back which feeds the warning light and that will stop it charging,
Reply 0
Dec 11, 2024 | 04:12 AM
Alternatively, you can pull Fuse #2 (5A) in the Engine Compartment Fusebox. Removes B+ feed to the alternator regulator.
Reply 3
Dec 11, 2024 | 04:20 AM
As always Michealh right again though there is always the chance the alternator will self excite is revved hard
Reply 1
Dec 11, 2024 | 04:43 AM
I found that out too late when my alternator decided to go south just before storm Ciaran.
Point taken though over possible self-excitement - residual magnetism?
Reply 0
Subscribe
Currently Active Users (1)
