Can the alternator be turned off temporarily?
Old Dec 10, 2024 | 09:31 PM
scottatl's Avatar
Default Can the alternator be turned off temporarily?
I am hunting a ground loop issue with my audio system and i want to find out if the alternator is the culprit. Is it possible to take the alternator out of the electrical loop for a short time for me to do a test. I don't see a relay or anything i can just pull to test this out.
Old Dec 11, 2024 | 01:50 AM
Pistnbroke's Avatar
No relay you need to pull the three pin plug on the back which feeds the warning light and that will stop it charging,
Old Dec 11, 2024 | 04:12 AM
michaelh's Avatar
Alternatively, you can pull Fuse #2 (5A) in the Engine Compartment Fusebox. Removes B+ feed to the alternator regulator.
Old Dec 11, 2024 | 04:20 AM
Pistnbroke's Avatar
As always Michealh right again though there is always the chance the alternator will self excite is revved hard
Old Dec 11, 2024 | 04:43 AM
michaelh's Avatar
I found that out too late when my alternator decided to go south just before storm Ciaran.
Point taken though over possible self-excitement - residual magnetism?
ericeric7
Jan 9, 2026 01:46 PM
John-Melanie
Jan 8, 2026 02:59 PM
petemohr
May 6, 2020 02:40 PM
David F.
Jul 3, 2019 12:54 PM
