Can I pul cable into the door pocket to power my phone
Old Jul 2, 2011 | 12:16 AM
scottatl's Avatar
Default Can I tap the electrical in the door pocket to power my phone
The door handle pocket is a great place for the phone. I would love to run a charger in the pocket. Any good wire in the door to tap into?
Old Jul 2, 2011 | 06:21 AM
Dennis07's Avatar
How much current does the charger draw?
Old Jul 2, 2011 | 06:33 AM
scottatl's Avatar
not sure it is for a blackberry. standard USB type charger
Old Jul 2, 2011 | 08:11 AM
WhiteXKR's Avatar
I spent a bit of time looking at the power available in the door when I was developing my remote top controller. It looks like only battery sourced power (not ignition switched) is available. Thus the charger would drain the battery unless it was unplugged each time.
If you look at my write-up in the 'drop your top' thread, I show how to run an ignition sourced power wire (the red/white one) from the engine compartment fusebox into the door. You can do that, or you can wait until the end of July when my remote top control module goes on sale, and you will get that wire in the door if you install my module.
Old Jul 2, 2011 | 11:25 AM
WhiteXKR's Avatar
Here is a nice outlet I have found:
Amazon.com: New Can-Am Spyder 12V Accessory Plug Jack Outlet: Automotive
hafren
23
Jan 3, 2025 11:26 AM
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
mrplow58
Sep 9, 2015 11:27 AM
