Can someone point to the fuel pressure regulator - pictures attached. Thanks!
I have a small fuel leak. The mechanic wants $800 to replace the regulator, which seems steep. The part is around $170 bucks on Amazon.
If someone can help me locate the regulator using the below pics I would appreciate it. I have read the procedure to replace the part so I think if I can get to it, I hope to be able to replace it.
I also noticed that the part comes with some O rings, I am going to check those first. Mechanics are often too quick to discard a good part when a simple fix is possible.
One more thing, is the part I linked to OEM? It is listed as OES, but I am not sure if that is a manufacturer acting like it is OEM or if it really is OEM.
I have a small fuel leak. The mechanic wants $800 to replace the regulator, which seems steep. The part is around $170 bucks on Amazon. link
