Cancelation cassette and indicator switch
Old Aug 30, 2015 | 03:25 AM
tberry6686's Avatar
Default Cancelation cassette and indicator switch
Probably a daft question but...
I am getting an airbag warning light with the flashcode suggesting that the problem is at the clockspring/cancellation cassette. For some time (since I bought the car) when turning right the indicator doesn't self cancel. If I have to change the cancelation cassette is this likely to also fix the indicator cancelation issue or do I need to replace the indicator switch as well (seeing as I will be in there anyway).
Old Aug 30, 2015 | 04:20 AM
jimbov8's Avatar
Many people have had this very problem and changing the clock spring will usually fix it.
That is what I would do first. Because of the airbag, make sure you disconnect the battery first but also make sure you have the radio code before doing so.
Old Sep 20, 2015 | 03:11 PM
tberry6686's Avatar
Managed to get a new clockspring on ebay (£140.00) and this has cured the airbag problem but sadly the indicator cancellation still does not work when turning right so I suspect the indicator switch itself has an issue.
Looking on Ebay for a replacement (cause the new price is just silly - £263 +delivery) I came across this.
INDICATOR STALK / STEERING COLUMN SWITCH - Jaguar XJ8 XJR X308 (also XK8 / XKR) | eBay
The part looks like the one in my XK8 but jaguar have different part numbers for the XK8 and XJ8. Can anyone confirm if they are the same part ?
Old Sep 20, 2015 | 03:22 PM
jimbov8's Avatar
Glad to hear you have part of your problem sorted. If you have a look at the top of this forum you will find a parts list that should help you. It is under the DIY Maintenance section.
Rivguy
Nov 13, 2022 02:55 AM
hamilton7550
Jul 30, 2021 11:29 PM
mrsteady
Sep 20, 2015 03:38 PM
dstary
Sep 19, 2015 09:47 AM
Mosers63
Sep 6, 2015 02:53 PM
