CD player skipping...What do I do?
Old Apr 30, 2009 | 01:41 PM
SirWilliam's Avatar
Default CD player skipping...What do I do?
I have a '98 XK8 and for what ever reason the CD player seems to be skipping at lot. After a while of skipping it just stops playing completely...is this something that could be solved with one of the CD lens cleaners or do I need to have the CD player replaced?
Thanks in advance for any replies.
Old Apr 30, 2009 | 11:58 PM
H20boy's Avatar
It couldn't hurt. I'd blow some compressed air in there first, try it and then go to the lens cleaner. You can get a replacement CD player at many salvage yards or ebay. For used (confirmed working order) contact jagtechohio (member on here). He's got lots of parts...could possibly help you.
Old May 2, 2009 | 05:25 PM
SirWilliam's Avatar
Thanks for your reply...are you sure spraying air in their would be safe?
Old May 2, 2009 | 05:47 PM
test point's Avatar
I think H20 Boy meant with a can of computer compressed air cleaner, not an air hose. I have cleaned a couple of CD/DVD players that were operating strangely and that took care of the issue. It is also a manufacturer recommended fix for my entertainment center Samsung DVD player.
Old May 5, 2009 | 09:52 PM
est190's Avatar
I think most of the jag cd changes have a tendency to skip (my '01 does in any case). Your 08 has a small buffer. You can pick up a new changer for not that huge of a dollar amount. Frankly, I am probably ditch the alpine head unit and put in a Kenwood with USB, aux, and parrot bluetooth with a pro install so it blends in with the factory look. It's really not that expensive and is superior to the OEM radio, which I find a bit fussy and the lack of ipod connectivity is big negative.
Old May 5, 2009 | 10:27 PM
H20boy's Avatar
If you have navigation... replacement is a total nightmare (and costly) unless you don't care much if the navigation works. It won't operate (besides the clock) w/o the factory deck in line with the rest of the components (amp/nav module).
Jul 9, 2018 01:44 AM
pilot435
Apr 8, 2016 06:16 PM
perezal
Dec 24, 2015 04:20 PM
mrsteady
Sep 20, 2015 03:38 PM
