Centre Console Illumination
Old Jun 17, 2009 | 10:48 AM
Raheny's Avatar
Default Centre Console Illumination
My centre console switches are not always illuminating when I switch on the headlights. Most buttons do illuminate, and sometimes all do, but there occasionally a couple of switches (usually different ones) failt to light up (so, it's definitely not the bulbs). Should I replace the entire centre console module? Is this expensive and tricky to do? Or is there something else I should be aware of that might be causing this?
Thanks in advance.
Old Jun 17, 2009 | 09:20 PM
H20boy's Avatar
More than likely, those bulbs behind that center console are just not making good contact in their little respective sockets. Cleaning the bulb contacts and the area where they meet the switches should clear that right up. I just screwed/unscrewed/screwed/unscrewed x50 times to fix my blinky. Works all the time now.
Old Jun 21, 2009 | 06:47 PM
Raheny's Avatar
Good point! Thanks for your suggestion. I know it's a total pain accessing the centre console. Is it possible to access the switchbacks without disassembling the entire centre console? It took me hours last time to do this.
Old Jun 23, 2009 | 10:13 PM
H20boy's Avatar
Not that I have found. Gotta take that center console/armrest, trim ring, shifter bezel, and surrounding pieces to get it out. Sorry.
Msteiner
May 16, 2016 12:19 AM
adam699
Oct 13, 2015 05:53 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
goingjag
Sep 30, 2015 09:27 PM
Rocky15
Sep 28, 2015 04:59 PM
