Chain tensioners
Old Oct 7, 2016 | 03:58 AM
Jugular's Avatar
Question Chain tensioners
I have a 2005 XK8 4.2 which is running perfectly (for the moment!). I assume it is fitted with the all-metal type 3 tensioners. Do these need any specific checking or servicing? Am I likely to need to replace them? The car has just covered 90,000 miles.
Old Oct 7, 2016 | 05:12 AM
test point's Avatar
There has been a couple reports of metal secondary tensioner failures but that is far fewer than the plastic versions. More on the order of what would be expected of any mechanical part. One part of the chain system that is of some concern is the primary slipper arms. They seem to have a life shorter than the total engine but do not cause the total engine failure of the upper tensioners.
kmeseck
Sep 13, 2017 09:25 AM
brgjag
Aug 31, 2016 11:10 AM
Michael_Toronto_Canada
Aug 28, 2016 05:37 PM
fredgarvinmp
Aug 28, 2016 01:09 PM
Jugular
Aug 22, 2016 03:37 PM
