Is this chain too loose
Old Aug 21, 2018 | 04:49 PM
IXLLER8's Avatar
Default Is this chain too loose
Hi...this is my second try.
Is this too much slack on the drive side...this is after change of tensioners, guides and chains but before start up, so no oil pressure in tensioners?
Tightened cam bolts but right bank seems too loose...was tight when I torqued the bolts, primary chain was wedged and I did the exhaust sprocket first.
What difference does it make that I do both banks before loosening cam locking tools..should I do left first and then loosen left locking tool before moving to right bank.
Old Aug 21, 2018 | 08:03 PM
JBzXJ40's Avatar
What chain are you referring to - primary or secondary chain being loose? And what area does the chain seem loose, can you post a picture.
You will have "some" slack on the tensioner side of the chain, this slack will disappear once engine is started and oil pressure goes up.
Old Aug 21, 2018 | 11:37 PM
IXLLER8's Avatar
Sorry - seems like my video won’t stick as attachment - willl try again later
Old Aug 22, 2018 | 02:09 AM
Put the video on YouTube or your host of choice and post the link to it .......
Old Aug 22, 2018 | 05:01 AM
IXLLER8's Avatar
Video is live...took some time, new to uploading videos on youtube...and have so far avoided having an gmail account:-)
Old Aug 26, 2018 | 09:51 PM
JBzXJ40's Avatar
Provided that you have the cam lock tools and flywheel pin in place correctly, this puts the engine is safe mode. Once the new chains, tensioners and guides are in place and torqued down, you can take the cam lock tools off. It doesn't matter what side you take off first. When you take them off, the cams might move slightly, but the slack is there because there is no oil in the tensioner, and the engine hasn't turned over. Once you start it and oil pressure goes up, the slack will go away. Just make sure you don't forget to remove the flywheel pin before starting it.
96xjsz
Feb 25, 2016 04:17 PM
Spikepaga
Sep 13, 2013 11:35 PM
TopHatChef
Jun 28, 2013 12:09 AM
Oct 28, 2010 11:12 AM
stype2000
Jan 11, 2009 04:40 PM
