Change rear shocks for standard.
Old Aug 11, 2022 | 09:31 AM
Pistnbroke's Avatar
Default Change rear shocks for standard.
My 97 has the electronically controlled shocks ...can I get standard ones for the rear and abandon the electronic ****? Or even are there shocks from more mundane cars that will fit ?
Old Aug 11, 2022 | 05:20 PM
michaelh's Avatar
I'm pretty sure that you can just disconnect the adaptive damping module without the car throwing a hissy fit.
But - the CATS shocks will default to the firm setting. Not sure how that would work out with two 'normal' rears?
Old Aug 12, 2022 | 12:53 AM
Pistnbroke's Avatar
Its the rears I find a bit hard on some road bumps. Will the standard ones fit in terms of mountings ?
If anyone has a old rear shock I would appreciate a photo with a ruler alongside or an extended and compressed length measurement.
Old Aug 12, 2022 | 01:18 AM
Kuddlesworth's Avatar
I have to agree with you there, I also have CATS and I find the rears to be a bit too stiff. The fronts seem to be just fine, whenever I go over a big bump I don't really feel the fronts but I do feel the rears. I think it would be best to ditch the 20" wheels all round and go for 18" wheels. I figure that should help a lot, if that isn't enough, probably go to the standard shocks or just refresh the whole suspension because it's now some 20 years old.
Old Aug 12, 2022 | 01:22 AM
Pistnbroke's Avatar
I have 18 in wheels.....could the rears be stuck in hard mode?
Old Aug 12, 2022 | 11:57 AM
How old are the shocks? If the wire was broken for the shocks or disconnected you would get an error on the dash. They might just be old and worn out same as the springs perhaps. I know mine are a bit worn out because the ride height is a bit wrong on all corners and mine is a 2003 car so it's a bit newer then yours.
JWestXJR2000
May 12, 2022 07:06 PM
Nic Graves
Dec 3, 2017 03:33 AM
Carthage4404
Jan 13, 2011 10:25 PM
