Charging
Old Mar 25, 2021 | 01:28 PM
1951sms's Avatar
Default Charging
My 1998 XK8 is charging fine but Battery Not Charging info on dash. Battery is new as well as Alt.
Old Mar 25, 2021 | 05:59 PM
ccfulton's Avatar
How have you determined that the battery is charging fine?
For the AJ26 it appears that the 3 pin connector on the generator has a wire specifically for the charge indicator.
A multi-plug (3 pin) is connected to the rear of the generator
Pin #1 not connected
Pin #2 ignition supply to the regulator
Pin #3 output to the charge warning lamp
This runs directly to the instrument cluster so maybe you have a wiring problem there? Or the connector is not well seated?
Old Mar 25, 2021 | 11:54 PM
DavidYau's Avatar
Default Some pics of my 99 XK8
1951sms
+1 to ccfulton. It’s a zero dollar check.
Here’s a pic showing the connector at the back of the alternator, after I removed the airbox for access, and removed the main positive cable.
Difficult to unplug and reseat this connector though. Good luck.
Old Mar 27, 2021 | 07:50 AM
1951sms's Avatar
ccfuton ,Thanks...I'll ck it out today!!!
Old Mar 27, 2021 | 07:51 AM
1951sms's Avatar
Davidfao, Thank you very much!!
Keith Veale
Feb 8, 2020 04:49 PM
UDATDERE
Apr 12, 2019 11:18 AM
Natalie Fieser Florea
Sep 18, 2017 03:52 AM
Plastic Paddy
Sep 19, 2016 08:53 PM
amaezing
Nov 28, 2015 05:41 AM
