Check Gas Cap/Check Engine Light
Old Nov 17, 2011 | 11:29 AM
srpope80's Avatar
Default Check Gas Cap/Check Engine Light
Hello,
Pretty new to this forum, and I was wondering if anyone had any knowledge of the folllowing issues.
I have a 2001 XKR Silverstone and the "Check Gas Cap" and Check Engine Light came on.
I was wondering if anyone has any ideas what could be the issue with this? Thanks in advance.
Scott
Old Nov 17, 2011 | 11:41 AM
eagledancer's Avatar
Had that when I became overly ambitious tightening my gas cap, I was listening for the "click" my Jeep has. The Jag (my 2000) doesn't "click" just snugs up and going beyond snug causes the cap to leak air giving the code. Fixed by restoring cap to "snug". After a few starts the check engine went away.
Old Nov 17, 2011 | 03:26 PM
calibrit's Avatar
My Jag XK8 did that once when I didnt tighten the gas cap all the way to hear it click and I had to plug in the OBD to clear it,never had the problem again.good luck
Old Nov 17, 2011 | 04:06 PM
mcbeefsteak's Avatar
Make sure the gas cap is "mechanic's touch" tight, and the code will eventually clear itself.
I believe you could clear it by disconnecting your battery for a bit as well, unsure.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
big d
Sep 3, 2015 07:37 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
daro31
Aug 27, 2015 09:26 AM
