Chime with Key On
Old Jan 9, 2014 | 06:40 PM
2ndxk8's Avatar
Default Chime with Key On
My XK8 is not giving the two or three chimes it normally does when key is selected on while doing its test. The lights do their thing and no codes but no chime is audible.
Any Ideas,
Thanks,
2X
Old Jan 9, 2014 | 09:11 PM
motorcarman's Avatar
Faulty/burnt-out speaker?????????????????????????
bob gauff
Old Jan 9, 2014 | 09:22 PM
2ndxk8's Avatar
Don't know. Battery was disconnected recently by independent mechanic to pull seat out for seat module failed. I will have to send module for repair. After picking car up chime doesn't work.
Old Jan 10, 2014 | 09:23 AM
smithtrevor's Avatar
In these modern times you normally have a "settings" menu and "chimes" is in there ?
Old Jan 10, 2014 | 09:26 AM
giandanielxk8's Avatar
I know what you're going through. I've never heard the chime in my car. Whenever I give a ride to someone for the first time, they usually start yelling at me for not using the turn signals. I have to tell them that in fact I do, but they've gone mute.
I think it's supposed to sound like the chime in the X308s.
Old Jan 10, 2014 | 10:23 AM
mike66's Avatar
Mine make a "tick-tock" noise.
Old Jan 10, 2014 | 01:02 PM
batroute's Avatar
Any Ideas,
Thanks,
2X
If you also don't have the turn indicator tic toc it's probably the speaker - less than $30 from the dealer. It is situated in the lower steering column shroud - very easy to change.
Old Jan 10, 2014 | 08:14 PM
2ndxk8's Avatar
My turn signal tic tock works fine, just the ding dong chime is not working during the light test.
2X
philwarner
28
Jul 11, 2017 10:21 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
