cigarette lighter
Old Jan 18, 2018 | 01:48 PM
DevonDavid's Avatar
Originally Posted by dsd
The OEM part is available from the usual sources for about $40. Be warned, It’s a pain to replace— you need to take the center console out and when you reconnect there is very little slack on the wire. Not hard, just annoying.
Not if you don't go OEM but - the illumination needs slight wiring modification !!
https://www.ebay.co.uk/itm/Cigarette...-/322550778822
Old Jan 24, 2018 | 10:53 AM
sean46's Avatar
Default Problem solved
As it turns out, the local Jag service said the cig socket was bent, so I just returned the new cig lighter because my cell phone charger works fine. The new lighter actually worked but I had to keep it depressed. It would not stay engaged and pop up as it's supposed to.
Arne
Aug 18, 2024 12:08 PM
orangeblossom
Sep 24, 2015 12:56 AM
dstary
Sep 19, 2015 09:47 AM
jagent
Sep 12, 2015 01:40 AM
tonydbaker
Aug 30, 2015 11:02 PM
