clicking brake
Old Jun 15, 2016 | 01:04 AM
mick99's Avatar
Default clicking brake
Brakes suddenly went to floor one morning. Brake fluid is full. In idle, with car in park, there is a clicking noise when brakes are applied. Seems to be coming from gear shift area? Any ideas?
Old Jun 15, 2016 | 02:48 AM
woox4's Avatar
Only guessing here but I'd look first at the mechanical linkages to the brake booster
Old Jun 15, 2016 | 04:16 AM
DevonDavid's Avatar
The clicking noise is normal - it's the solenoid that releases the interlock on the gear shift (so you can't engage "D" unless you have a foot on the brake pedal.)
If there's no loss of brake fluid, and the pedal goes to the floor - then I would suspect the master cylinder seal. I assume the brakes don't work ? If you pump the pedal, is there any loss of fluid, or do you get any improvement in brake performance ?
Woznaldo
Jul 20, 2016 02:24 AM
Billy Syeon Harsh
Apr 11, 2016 07:31 PM
Andi Baker
Apr 9, 2016 05:51 AM
multiplecats
General Tech Help
27
Apr 5, 2016 09:42 AM
oyster
Apr 3, 2016 09:41 AM
