That was close!!!
Old Aug 17, 2012 | 03:51 AM
XKRacer's Avatar
Default That was close!!!
I have a early XK8 in for some acident damage repair work, noticed a bit of a noise from the righthand bank, the owner did mention he had a slight oil leak, figuring I had to sort that anyway I will take a look...
Oil leak was just a couple of loose bolts on the corner of the cam cover but the knocking..... Ooooooh dear what a mess
That is the closest I have seen before implosion!! The tensioner piston is actually seperated from the body, what is left of it, the chain has been running for quite a while on the slipper at odd angles by the grooves worn into it, so very very close.....
Old Aug 17, 2012 | 05:10 AM
steveinfrance's Avatar
The owner must do several good deeds a day to get away with that.
Next time they're having a drink with the Good Luck Fairy will they ask her to call by sometime please?
Old Aug 17, 2012 | 05:53 AM
philwarner
28
Jul 11, 2017 10:21 AM
hkmcmast
Nov 29, 2015 06:56 AM
millertic
Sep 30, 2015 08:11 PM
