conv top 004 xk8
Old Sep 27, 2017 | 01:16 PM
Mayor of Taus's Avatar
Default conv top 004 xk8
Put top down, latch did not retract. warg hood not latched! 40 a fuse blown, install new fuse, blown again. relay?
Old Sep 27, 2017 | 02:37 PM
avern1's Avatar
You can check relay by swapping the top up relay with the top down relay. If you are still blowing the fuse I would check to insure the pump is running. You can remove the panel in the boot and access the pump, then turn the T-shaped handle to open position to by pass pump pressure. You can use the allen wrench mounted on the pump to cycle the latch and make sure it isn't frozen.
With the pump on bypass and a new fuse installed have someone press the button to energize the pump. Is it running? Also while you are back there check to make sure fluid is in good condition and at proper level.
Old Sep 27, 2017 | 02:45 PM
WhiteXKR's Avatar
If the 40 amp fuse consistently blows, the TVS diode in the motor is the most likely cause. See XK8 Convertible Top, Fixing the Motor
Old Sep 27, 2017 | 03:02 PM
Welcome to the forum Mr Mayor,
Now that you have some good advice please find the time to post an intro in the new members section.
JimC64
Sep 22, 2025 02:52 PM
srpope80
Jul 13, 2019 08:03 PM
Phil Preece
Oct 17, 2016 01:41 AM
zc_sandman
Oct 15, 2016 02:13 AM
Dec 21, 2006 10:33 PM
