Coolant hose connector leak
Old Mar 25, 2019 | 06:20 PM
robot808's Avatar
Default Coolant hose connector leak
Finally located the source of the coolant leak on my 01 XK8. It looks like a hose connector T that is just under the left side of the throttle body and has a line that runs up to the back of the throttle body.
Is that connector sold separately? Anyone have a part number number for me?
Thank you for any help!
Old Mar 25, 2019 | 06:26 PM
robot808's Avatar
Or...
Can this just be replaced with a brass plumbing T? Or is there some kind of check valve in there?
Anyone know the inner diameter of the hoses there?
Old Mar 26, 2019 | 07:59 AM
fmertz's Avatar
It is not a simple T, the firewall side of this (right side of your pic) mates with the famous octopus hose. It is a quick-connect Norma connector that is great for Jaguar at the time of assembly. It believe this special T is available separately.
To be a bit more complete, the radiator side of this T(left side of your pic) mates with one of the infamous valley hoses. These valley hoses are running from the front thermostat tower, and feed the heater code (not directly, though). These hoses are great, until they are not as they age hidden under the intake. This simple leak can be a hint that these hoses need to be replaced. I replaced mine a few weeks back, and it was not a pretty sight: hoses swollen beyond recognition, and even had a small tear in it. This is a job with quite a bit of labor, but pretty cheap in parts. Perfect DIY.
Old Mar 26, 2019 | 04:02 PM
michaelh's Avatar
^^ +1
It looks like someone has been there before as the original tee is missing. This is what it should look like:
https://www.jaguarforums.com/forum/x...4/#post1932330
srpope80 has done an excellent write-up (lots of pictures) of the job in this thread:
https://www.jaguarforums.com/forum/x...1/#post1975355
Old Mar 26, 2019 | 07:09 PM
robot808's Avatar
Gentlemen, thank you so much! That looks like all the info I need to get this done.
I'll report back once I've had a go at it!
I really appreciate your help!
Blue_XJ8
Mar 12, 2018 08:04 PM
jagdohrman
Jul 1, 2017 11:36 AM
Some Day, Some Day
Dec 31, 2016 03:13 AM
Michael Star
Jan 30, 2013 09:31 PM
srpope80
Jan 26, 2012 04:02 PM
