Coolant level
Old Aug 5, 2011 | 07:05 PM
walkman1's Avatar
Default Coolant level
Is it common for the coolant in the overflow tank to be down a little every few hundred miles, or do I have a hidden leak? It seems to down about a cup every other month.
Old Aug 5, 2011 | 07:40 PM
test point's Avatar
The XJ/K series is famous for little leaks on the order that you describe. The best solution is to do, or have done, a pressure test on the coolant system. Most auto parts stores will 'rent' you a pressure test kit for free. Pump it up with the engine cold and you will probably see a little leak.
Old Aug 5, 2011 | 11:39 PM
turbo68's Avatar
I had same issue and it turned out to be my thermostat housing. No issues after I replace it.
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
vwbusbits
Oct 13, 2015 03:43 AM
dmatthewman
Sep 30, 2015 10:10 AM
