Coolant overflow hose
Old Feb 18, 2011 | 08:36 AM
kvmentor's Avatar
Default Coolant overflow hose
I have a leak at the engine end of the coolant overflow hose (2000 XK8). I ordered and received a new hose ($26 incl shipping from autopartswarehouse.com). However, the existing tube or hose has two circlips, one at the engine and the other at the coolant overflow tanks.
I was wondering if someone can help - are the existing clips easy to take off and more importantly are they reusable? I havent tried to take them off yet for that reason.
Thanks for any info.
Kal
Old Feb 18, 2011 | 09:23 AM
WhiteXKR's Avatar
There is a special tool for those 'clic' type hose clamps., but they can also be removed with a pair of pliers and a small flatblade scredriver as follows:
Pry open the clamps with a small screwdriver in the rectangular window on the clamps. While gently prying, squeeze the clamps together by their outermost ears with a pair of pliers.
They can be reused as long as you are gentle and do not deform them.
Old Feb 18, 2011 | 02:24 PM
daddyo007's Avatar
If they deform just get some breeze clamps.
http://www.breezeclamps.com/euroseal.htm
these should be readily available.
Old Feb 18, 2011 | 05:44 PM
kvmentor's Avatar
Thanks! Will try prying them out, if not will have breeze clamps ready!
Old Feb 18, 2011 | 06:51 PM
hlgeorge's Avatar
I replaced a coolant line from the tank to the connection at the front of the engine. Clamps popped open with a screwdriver and clamped closed with pliers. Working fine for 3 years now.
Old Feb 19, 2011 | 08:24 AM
kvmentor's Avatar
I pried the clamps open (pliers to gently pull the prongs together and then pushed the claw foot upward to release the clamp) and replaced the overflow tank hose.
Was able to reuse the clamps and the car is a go.
Thanks whitexkr, daddyo and hlgeorge
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
vwbusbits
Oct 13, 2015 03:43 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
