Corroded Valve cover bolts and Studs
Old Mar 14, 2020 | 07:00 PM
NBCat's Avatar
Use a fuel line disconnect tool to release the connector. The Bank2 cam cover cannot be removed without disconnecting the fuel line.
Once the fuel line is disconnected, cover the fuel rail joint with a rag to prevent dirt entering the system. When reassembling, inspect the o-rings and push the fuel line into the fuel rail until a click is heard.
Old Mar 14, 2020 | 07:01 PM
NBCat's Avatar
https://www.ebay.com/itm/Car-Fuel-Ra...kAAOSw2cRcdT6S
Old Mar 14, 2020 | 09:21 PM
giandanielxk8's Avatar
Do you happen to know what size disconnect tool I need? And on what part of the fuel line does it go? The bell at the fuel rail?
Old Mar 15, 2020 | 01:42 PM
Final update:
I finished the job. The fuel line released easily with the right quick disconnect tool.
I decided to only change the driver’s side gaskets as the passenger side was completely dry. In case that side starts leaking, I already have the gasket, seals and grommets.
Old Mar 15, 2020 | 05:06 PM
JayJagJay's Avatar
Good job, Bro! Good job!
Lagonia
19
Apr 18, 2021 02:19 PM
Benji999
Nov 6, 2016 10:56 AM
pdupler
Apr 25, 2015 08:11 AM
JBfountain
Feb 27, 2015 11:41 PM
