Couple quick questions on Monday morning......
Old Mar 12, 2012 | 07:34 AM
John Fox's Avatar
Default Couple quick questions on Monday morning......
So Ive noticed recently that when using the fan only mode with the windows up that the smell coming from the vents is rather stale. Is there an interior air filter on these that can be changed ? Or....... anyone have an idea what I can do to fix the smell.
Secondly, last week while sitting in the car with it running waiting for a friend I smelled gas. Not bad but I did smell it. Cant believe this is normal so....... any thoughts ? places I should check ? car isnt leaking anything that I can see and the smell is inside only and not with the fan on or the heat or ac.
Old Mar 12, 2012 | 07:53 AM
jmarshall's Avatar
This smell is due to the water condensation inside the evaporator core. Evaporator drops water from condensation it settles in the housing and becomes stagnated and causing bad smell inside the car interior.
Many cars (might be yours) having the fuel pump that is accessible directly through the driver cabin. so piossibly due to the shrinking of pump seal you're smelling the gas inside the cabin.
Old Mar 12, 2012 | 08:06 AM
WhiteXKR's Avatar
Regarding the gas smell, there a several possible causes. There are two factory TSBs on the subject. See this thread: https://www.jaguarforums.com/forum/x...s-smell-50466/
Old Mar 12, 2012 | 02:49 PM
Beav's Avatar
Re: stink - check out www.airsept.com
Old Mar 13, 2012 | 10:24 PM
H20boy's Avatar
I found my vent flap padding was SATURATED and always stunk...search for 'fight the stank' for my thread on how I got it scraped off and rid the cabin of the stagnant smell every time I started the a/c or opened the vents.
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
luc891
Jul 14, 2016 06:27 PM
WinterJag
16
Oct 9, 2015 07:49 PM
teacoff
Sep 10, 2015 08:25 AM
