cruise control for 1998 Jaguar xk8
Old Jul 2, 2014 | 03:17 AM
Jack22071941's Avatar
Default cruise control for 1998 Jaguar xk8
Hi,
Can anyone help, I need fitting instructions to fit a cruise control to my 1998 Jaguar XK8?
Kind regards
Jack Eltis
Old Jul 2, 2014 | 04:32 AM
Welcome to the forum Jack,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to XK8/XKR forum. Members here with the same model will be able to help.
Old Jul 2, 2014 | 05:07 AM
spuddyo's Avatar
Originally Posted by Jack22071941
Hi,
Kind regards
Jack Eltis
I guess it all depends how much your car has fitted and how much it hasn't. If you have a 97 -98 throttle body, does it have the vacuum bellows fitted on top ? You will also need the steering wheel controls, centre console switch, vacuum control valves mounted under right hand side wing, maybe a replacement brake switch. Oh, and fingers crossed the ecu /body control modules are already cruise equipped which I guess they will. The wiring and pipe work should be easy enough, you will need the circuit schematics for the 97/98 car.
ClassiXtype
Oct 22, 2023 05:29 AM
TheWarlock
Sep 7, 2015 09:30 PM
big d
Sep 3, 2015 07:37 PM
aquifer
Aug 29, 2015 04:54 PM
DeaconHull
Aug 28, 2015 05:26 PM
