Data Link Connection Error
Driving home last night and the old girl's engine started to stumble on the slightest attempt to accelerate. Felt as though a coil had stopped working and misfiring on less then 8 cylinders so I wasn't too worried. (been there done that)
When I got home to investigate, I hooked up the OBDII Scanner and it lights up, goes through its diagnostics as it always does, but then gives a
'cannot connect, data link error' at the end.
As it is going through its series of tests, the dash message info center starts flashing all the warnings, electrical fault, asc/trac inop, transmission failure, limp home mode, etc. After I get the unable to connect, the info center goes to open drivers door only. Check engine light will light when key is turned and goes off when it idles, but doesn't stay on?
I have tried hard reset, battery disconnected and grounded all night. I pulled the ECU and nothing obviously burnt inside, but I'm no expert.
The OBDII is working. It was in the jag a few weeks ago working fine, just tested it on a Land Rover, Ford, and Chrysler and communicates fine with all of them.
I pulled obdii port to find any broken wires as stated in earlier posts and found nothing obvious.
ANY way to get codes without scanner, or any quick fixes or are we looking at an ECU/ECM problem?
I would try another OBDII reader. If that one will not communicate either, I would suspect a faulty ECM, INSTPK or network harness.
The Instrument Pack is the gateway to all the other modules on the CAN bus and SCP network and if it fails, the network will probably fail to communicate properly.
I don't know if you are using the Serial Data Link or the CAN bus for communication.
Different diagnostic 'scanners' use different protocols.
I had a customer XKR that would communicate with the WDS through the CAN bus but a generic scanner would NOT communicate with the ECM through the Serial Data Link.
More diagnosis??????
good luck
bob gauff
good luck
bob gauff
trosty
26
Dec 18, 2022 06:40 PM
scooternva
19
Oct 27, 2015 02:14 PM
Foosh
Sep 11, 2015 03:35 PM
