Dead Battery, now nothing.
Old Apr 20, 2013 | 11:25 AM
BrianL99's Avatar
Default Dead Battery, now nothing.
I did a search, but couldn't seem to find an answer.
'97 XK8 was sitting in my garage for a couple of months. Went to start it, but of course the battery was dead. There was enough power to open the trunk & some dim lights in the cockpit. Charged the battery and drove away a couple of hours later, without any problems.
Parked it back in the garage and tried to start it 2 days later.
Not enough power to open the trunk lock and almost completely dead in the cockpit, although the dash warnings came on when I turned the key.
Put the battery charger on and lights, horn, everything seems to be working fine ... but not even a "click" when I turn the key to start it. If it was my motorcycle, I'd say hit was the "lean over switch" that has to be reset.
There's absolutely nothing when I turn the key, like there's a "reset" switch of some kind. Am I missing something here?
Old Apr 20, 2013 | 11:39 AM
Mikey's Avatar
Have the battery load tested. 99% chance it's toast. Never allow a battery to go dead while in storage, use a tender.
Old Apr 20, 2013 | 11:51 AM
jimbov8's Avatar
Hi Brian,
+1 on the battery. Prior to fitting a fully charged new battery, it may be advisable to check the ground points around the car to ensure they are all in good condition and tight.
If you do leave the car, make sure you deadlock it or as stated above use a battery tender.
Hope this helps,
Old Apr 20, 2013 | 11:52 AM
BrianL99's Avatar
I wasn't planning on "storage", but the weather worked against me!
You're probably right about it being toast. That I can live with, I just can't live with the "Lucas Electrical Gremlins" like the old days!
Old Apr 20, 2013 | 03:51 PM
BrianL99's Avatar
Originally Posted by jimbov8
Hi Brian,
Hope this helps,
You guys were right, it was just a dead battery. I guess once it runs down that low, there's nothing left to charge.
Thanks !
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
kevinl
Oct 31, 2019 06:15 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
