Diagnosing a defective ABS/DSC Module
I think some of those codes are a distraction. P20EE is a generic Ford DTC which I can't find in any of the XK DTC lists.
There's something here that matches your issue, and points to the ABS module being the culprit:
https://www.justanswer.com/jaguar/1z...d-message.html
I'd go with motorcarman's advice. Hopefully your local techs will be equipped to do the necessary.
Ken,
I would see if your origional ABS, that is the one you are having problems with, can be reconfigured to your car. Somehow when you took your ABS module out and repaired it the ECM doesn't recognize it anymore. See if the reconfiguring works. If it doesn't I have a 5 pipe ABS module from a 97. We can put that in and then have it configured to the car.
Those are SCP network errors (SCP+ and SCP- wires) for your instrument pack (speedo/odo). The body network is SCP, not CAN. Different wires.
Have you been working with the wires anywhere inside the cabin? Alternatively, has the instrument pack been removed and pins potentially bent?
Just thinking out loud, but maybe your problem is entirely a CAN connectivity issue. With the transmission module being much easier to access and that being directly connected to ABS module it might pay to check the value of the CAN wires running from Trans module to the ABS (TCM plug 82 green and 83 yellow) just on the off chance you have a break or such. Not sure what the value should be but maybe simply compare to the other pair of CAN wires on 85 and 86 same plug that run to ECM. Even a clue might help.
So, that means I guess I still need to take the car to the Jag shop and pay for the diagnosis AND a "reconfiguration" if they will do it. That's gonna cost me, but I don't want to pay them to R&R the module unless it's very reasonable. My question to you is, should I line up a professional rebuild and be ready to send the module from my garage or the shop? OR....wait and see what they come up with.
BUT....I noticed that the car in the side of the picture is a Cadillac. :O So, are there "C" codes for every newer car, and has nothing to do with Jaguar?
Here's my information link: https://www.jaguarforums.com/forum/x...t-38112/page4/
I did purchase a iCarsoft LR V2.0 scanner. It's overcomplicated and I don't know if it will read, erase and manage the C codes. I still need one that will do the reconfigure if I don't want to pay the shop. I had to email the company with questions and have not heard from them yet. But with a prompt from another member I surveyed the Innova 3130C. Available on ebay for half what I paid for the iCarsoft, and known to read "C" codes, etc. I also saved a newer model, the Innova 6030P that not only says it will read the ABS codes and "C" codes,there is a picture of the scanner with a "C" code diagnostic on its screen.
Second, I DID get a response (within 24 hours) from AUTOENGINUITY. Unfortunately, they said NONE of their scan tools can "flash", "reprogram", or "reconfigure" any module(s).
So, back to square 1.
Quick update: First, I STILL have not had any response from iCarsoft regarding the LR V2.0 that I bought from them. So, just put that in the "NO TECH SUPPORT" column.
i have the icarsoft LR-1. What is the issue you are having with the LR-2 ? I might be able clarify.
Z
First, even though the scanner identifies my car by VIN, and even after I insert the model and year, I do not find ANY link or prompt for Jaguar chassis codes....much less any related to the ABS or CANBUS modules or system. When I do a manual scan after running/driving the car so the CEL P1637 shows up, there is still no prompt for a chassis code. I also get a TCM lack of communication code (P1798), and still no "C" codes or prompts for the chassis codes. This unit is SUPPOSED to read all Jaguar codes.
BIG QUESTION HERE: if my ABS module repair was done correctly and the module is actually working fine....and there are no more ABS or chassis issues, does that mean there IS NO CODE TO REPORT???? And, that would be why I cannot get even a prompt for any Jaguar chassis codes?
Second, and not surprisingly at this point, there is NO function for it to "reconfigure", "reprogram", "flash", or "reset" the communication between the ABS and ECU modules. NADA! It vaguely hinted in the manual under 6.2.7 that the system would need "bleeding" (a function the scanner claims to perform) and then some kind of final action. All I see is a typical manual brake bleeding operation where you get down and loosen one of the brake bleeder nipples and have someone pump the brakes. BFD! That's IT!
Anyway, I tried to resend my original "tech help" request that was never answered....along with a SHARP rejection of them and their product. My resend was actually kicked back from their advertised email address (support@icarsoft.us).
If you have ANY better information or success with your iCarsoft I'd appreciate your help.
Exasperated Ken.
First, thanks for responding. I have two huge disappointments with the LR V2.0.....beyond the ridiculous "tech support" (lack of it).
Exasperated Ken.
Exasperated Ken.
I have an icarsoft which initially did very little but after update from version 20 to version 50 is much more useful.
Be aware that iCarsoft has never offered any customer support, period. I purchased their i930 back in February 2016 and had some communication issues with it. I e-mailed them multiple times and the only response I ever received essentially said "Sorry for your issues, we will contact our field engineer and see if he can assist." No response after that. I eventually got the device to work (sporadically) on my wife's 2006 XK8 but it refused to communicate with Wayne's (cjd777) 2000 XK8. Sometimes it will communicate with the 2006 car's various modules and sometimes it will not. I updated it with the latest iCarsoft download several years ago and that probably helped, but I have not used it in quite some time....
I also have an iCarsoft i903 for my 2013 Subaru and an iCarsoft TYT V1.0 for my wife's 2015 Lexus. They are both more consistent, more useful, and therefore more valuable than my inferior i930 is....
I should try that. Does it need to be connected to the car while I do this....or are all the updates stored withing the scanner itself? I'm a heavy computer/internet user, but not a program changing geek. Is there a prompted path to doing the updates?
The procedure should be outlined in your icarsoft manual. Just a matter of plugging into USB port on computer and other end to scanner USB (mini or micro USB, no car connection involved) and navigate to icarsoft support page, pretty straightforward download/ install.
I recently purchased and had installed a replacement ABS module from Module Repair Pro. Great service and easy to work with. I had the ABS unit installed by a local repair shop. Car is running perfectly. $300 for the ABS module and $250 for the install.
Is that the Module Repair Pro that advertises on Ebay? If so, they said they'd try to fix mine even though it has been re-soldered. I guess they had a module that matched you car. Good move to get back on the road.
I'm gonna pull it out and send it to Module Repair down in Van Nuys. But first, as you suggest, I will try to update my iCarsoft and take another shot at getting more information. I don't understand how an analyzer cannot communicate with the module that is installed.....unless there is a total disconnect from the CAN? But, I think that's impossible. Maybe.
I also sent my module to Module Repair Pros and it came back quickly. I have not installed it yet. I want to try what MOTORCARMAN suggested to connect and test the module without re-installing it. Don't know how with the really short harness and pump leads.
