Disabling the fuel pump
Old Sep 23, 2019 | 10:01 PM
Ronald Vennell's Avatar
Default Disabling the fuel pump
When I go the start the car after the timing chain guide upgrade I want to crank it without the engine starting until the oil pressure comes up. Is the process as simple as pulling the fuel pump relay?
Old Sep 23, 2019 | 10:31 PM
avern1's Avatar
Yes you can just pull the fuel pump relay. Let us know if you need a location. It is in the boot fuse box.
You can also press the accelerator pedal all the way on the floor and hold it down. That shuts off the injectors and the engine won't start. Keep it on the floor while cranking.
Old Sep 24, 2019 | 04:34 AM
Thank you! I was fairly certain that pulling the relay would do the trick but was concerned that it might disable something else in the starting circuit.
Interesting that holding the accelerator to the floor disables the fuel supply also. I assume that's for clearing a flooded engine. Is that commonly done on FI systems?
Old Sep 24, 2019 | 05:47 AM
RJ237's Avatar
Flooding is not a common occurrence on FI engines, but is seen occasionally on the nikasil Jags because the liners are so slick.
scottpeterd
Jan 10, 2026 04:47 PM
WhiteXKR
Jul 22, 2023 04:49 AM
ahunt4
Apr 8, 2015 08:44 PM
Bentas1ent
XJ40 ( XJ81 )
Aug 7, 2012 07:05 PM
ronmexico
May 4, 2012 05:55 PM
