DIY Installed the RealGauge today :)
Old Jul 18, 2017 | 06:20 AM
Salo's Avatar
Smile DIY Installed the RealGauge today :)
Hi Gents & Ladies,
finally installed the realgauge today, thanks to Steve for the quick delivery and the excellent instructions, it was an relative easy DIY job, but I almost got an heart attack when I re-connected the battery once I was done, Nothing - I mean nothing happen on the main instrument cluster - almost got panic - but then quickly realized that I must have missed to connect the main instrument connectors somehow, so of with everything again - re-check - and Yes - it was the main instrument connectors that I did not mount properly - I missed to push the level to the sides both on left and right side -
ref "Then push the connector in firmly. Then rotate the bail TOWARD the cable end and the connector will self seat and lock
once that was fixed - then next thing was a new error engine code - connected the OBDII and run a diagnostic reset - all fine - code went off - and after some test, everything runs fine !
I'm really happy to be able to read my engine coolant temp without being connected to the OBDII all the time - thanks Steve for making this upgrade available to us !
I share some pic's below as it may be useful for others who plan on fixing the
stupid original non functional temp gauge
realgauge cooling temp module + wiring from Steve @ thejagwrangler.com
disconnect the battery, btw - lower the steering wheel prior You disconnect the battery
lower panel off
remove main instrument cluster
removed the left ventilation, so it's easier to move the instrument cluster out
T-20 torx screws
new temp module mounted
wiring left
wiring right
electric tape!
OBDII say's 85C - new cooling temp shows 85C - perfect
Old Jul 18, 2017 | 07:19 AM
Orthodixie's Avatar
Did the same thing. Congratulations on a successful installation. I am most satisfied with the RG.
Old Jul 19, 2017 | 09:58 AM
dsd's Avatar
dsd
Its on my To Do List. Probably this fall.
Old Jul 19, 2017 | 08:43 PM
Papadog's Avatar
I've been thinking about putting this in my list fro this winter, probably will now!
Old Jul 19, 2017 | 10:15 PM
Orthodixie's Avatar
I urge you not too delay.
