Door adjustment
Old Jun 5, 2015 | 01:53 PM
Volbrewer's Avatar
Default Door adjustment
I need to raise the rear of the driver's door about 3/8" to get it properly aligned, so I need to get to the hinges to re-position them a bit. Any way to do it without removing the fender?
Old Jun 5, 2015 | 03:53 PM
WhiteXKR's Avatar
Is the misalignment also at the hinged end of the door, or does is grow worse as you move toward the latch? If it is the latter, door sag is common on these car due the long, heavy door.
It sounds crude, but door sag, in most cases it can be corrected by opening the door, grabbing the end with two hands and simply heaving the door upwards.
Old Jun 5, 2015 | 04:57 PM
Volbrewer's Avatar
Guh-wow! That do sound crude, but I have to say I've been really stressing looking at what it might take to get to those blasted hinges. I figured one or more generously proportioned PO's had been using the door as a crutch to get in and out, but long door/sagging makes sense. I'll gladly give the old heave-ho a try. Thanks!
Old Jun 5, 2015 | 09:05 PM
platinummaker's Avatar
Had the same with my 98 very. Went to the body shop that does all of the Jag dealership work, and they put a handle type device on the door and lifted it up. It's been good for over 5 years now.
Old Jun 5, 2015 | 09:15 PM
HokieJag's Avatar
Gave my sagging passenger-side door a heave last year - it took 2 or 3 tries to get it right, but it did the trick.
Old Jun 5, 2015 | 11:47 PM
scottatl's Avatar
i actually took a jack with a wood block and pushed it back up, worked like a charm.
Old Jun 6, 2015 | 08:44 PM
RCSign's Avatar
As written by Scott
I've never had the problem with the Jag.
When we owned our collision repair center back in the 70 & 80's that was one of the easiest adjustments.
99xk8guy
Sep 29, 2025 10:51 PM
Samheath100
Sep 17, 2015 10:03 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
jagent
Sep 12, 2015 09:10 AM
TexasCat
Sep 8, 2015 04:36 AM
